Follow these steps to remove a hard disk drive carrier from the chassis.
Remove the front bezel (see Removing the Front Bezel).
Select the drive bay where you want to install or replace the drive.
Drive bay 0 must be used first, then drive bay 1 and so on. The drive bay numbers
are printed on the front panel below the drive bays.
Remove the drive carrier by pressing the green button to open the lever.
(See A in Figure 195).
Pull the drive carrier out of the chassis.
Figure 195
Removing the drive carrier
