Navigating the Dashboard
- Setting Up the Controller for the First Time
The controller must first be set up on the network. - Logging On to the Web Interface
- Web Interface Features
The web interface is the primary graphical front end for the controller and is the primary interface - Changing the Administrator Password
- Setting User Preferences
You can configure the language in which the user interface must appear, and also customize the session tie for the interface. - Logging Off the Controller
You must be aware of how to log off the controller using the web interface and the CLI. - Configuring Global Filters
The Global filter setting allows you to set your preferred system filter. - Warnings and Notifications
This section explains about warnings and notifications. - Health and Maps
The Health dashboard gives you a very high-level overview of wireless devices such as cluster, AP and clients, and wired devices such as ICX switches. For wireless devices, it displays a world map view using Google Maps, which provides a global view of your SmartZone-controlled wireless network deployments. - Traffic Analysis
You can analyze network traffic for APs, WLANs and clients.
