Sending the Guest Pass via SMS
To send guest passes via sms, you must have added an external SMS gateway to the controller.
Follow these steps to send the guest pass via email.
  1. From the generated guest passes list, select the guest pass that you want to send via SMS.
  2. Click SMS. SMS options appear on the right side of the page (see Figure 128).
  3. In Guest Instruction SMS Template, select the SMS template that you want to use.
  4. Click Add New.
  5. In the box that appears below, type the phone number to which you want to send the guest passes via SMS.
  6. To add another SMS recipient, click Add New again, and then type another phone number.
  7. When you have finished adding all the SMS recipients, click Send SMS. A dialog box appears and informs you that the SMS messages have been sent to the message queue successfully
  8. Click OK to close the dialog box.
You have completed sending guest passes via SMS.
Figure 128  Options for sending guest passes via SMS
