Viewing Statistics for GTP Core Network Tunnel
You can view historical traffic statistics and trends of th core GTP tunnels.
GPRS Tunneling Protocol (GTP) transmits user data packets and signaling between controller and GGSN. GTP encapsulates traffic and creates GTP tunnels, which act as virtual data channels for transmission of packet data between the controller and GGSN. A GTP tunnel is established between the controller and GGSN for a data session initiated from UE.
To view Stats for GTP Core Network Tunnel:
- From the left pane, select Report > Core Network Tunnel Stats. The SoftGRE page appears.
- Select GTP and update the parameters as explained in Table 52.
- Click:
- Load Data— To view the report in the workspace.
- Export CSV—To open or save the report in CSV file format.
| Field | Description | Your Action |
| Time Period | Indicate the time period for which you want to view the report. | Move the slider to set the duration. |
| Zone Name | Indicates the zone. | Select the Zone name. |
| Gateway Address | Indicates the gateway address. | Enter the gateway address. |
| AP MAC or IP Address | Indicates the MAC of the Access Point or IP Address. | Enter the AP MAC or the IP address. |
Table 53 contains the report based on the statistics for GTP. Each entry contains the 15 minutes cumulative data.
| Field | Type | Description |
| Time | Long | Bin ID, which is stamped at a 15 minute interval. For example, 10:00, 10:15. |
| TX Bytes | Long | Indicates the number of bytes sent. |
| RX Bytes | Long | Indicates the number of bytes received. |
| TX Packets | Long | Indicates the number of packets sent. |
| RX Packets | Long | Indicates the number of packets received. |
| Tx Dropped Packets | Long | Indicates the number of packets dropped while sending. |
| Rx Dropped Packets | Long | Indicates the number of packets dropped while receiving. |
| Bad GTPU | Long | Indicates a tunneling mechanism that provides a service for carrying user data packets dropped. |
| RX TEID Invalid | Long | Indicates the number of invalid packets received by Tunnel End Point Identifiers. |
| TX TEID Invalid | Long | Indicates the number of invalid packets sent by Tunnel End Point Identifiers. |
| Echo RX | Long | Indicates the echo message received. |
| Last Echo RX Time | Long | Indicates the time when the last echo message was received. |
