Rehoming Managed APs
Rehoming is the process of returning the APs that have failed over to the standby cluster back to their original cluster (once it becomes available). Rehoming must be done manually. APs that have failed over will continue to be managed by the failover cluster until you rehome them.
You can rehome managed APs, only in a cluster redundancy enabled environment. When APs of a certain active cluster failover to a standby cluster, you must manually restore them to the original cluster, once the active cluster is fixed and back to service. See
Enabling Cluster Redundancy.
Rehoming APs must be done on a per-cluster basis. Follow these steps to rehome managed APs to the original cluster.
- From the Access Points page, select the System to activate rehome operation.
- Click More and select Rehome Active Cluster . A confirmation dialog box appears.
- Click Yes, you have set all APs in the standby cluster to rehome to the active cluster to which they were previously connected.
