Disabling Cluster Redundancy from the Active Cluster
To disable the cluster redundancy from the active cluster when the active cluster is in-service, perform these steps.
You have disabled cluster redundancy from active cluster when the active cluster is in Service.
If the active cluster is out-of-service, use the Disabling Cluster Redundancy from the Standby Cluster task.
