Applying a WLAN Template
You can apply only WLAN-related configuration to an AP zone using a WLAN template. You can apply the WLAN template to zones where the AP's firmware version is later than the Zone templates firmware version. Unsupported firmware version of the WLAN template is automatically upgraded to its next version before being upgraded to the current version.
Follow these steps to apply a WLAN template:
- From the Wireless LANs page, locate the zone where you want to apply the WLAN template.
- Click More and select Apply WLAN Template, the Apply WLAN Template dialog box appears.
- From the Select a WLAN template drop-down, select the template.
- Click Next, the Apply WLAN template to selected zones form appears..
- Click the required options:
- Create all WLANs and WLAN profiles from the template if they don't already exist in the target zone(s)
- If the target zone(s) has WLANs or WLAN profile with the same name as the template, overwrite current settings with settings from the template.
- Click OK. A confirmation dialog appears.
- Click OK. You have applied the WLAN template to the zone.
