A Bonjour Gateway policy must be created for an AP
    zone before the policy can be deployed to an AP or group of APs.
    To create a Bonjour Gateway policy:
        Go to .
        Select the Gateway tab, and then select
          the zone for which you want to create the policy.
        Click Create.
         The  Create Bonjour Policy page appears. Figure 159
            Creating a Bonjour Gateway Policy
        Configure the following:
            - Name: Type a name for the policy.
- Description: Type a description for the policy.
- Rules: Create the policy rule by configuring the following
                - Click Create. The Create Bonjour Policy Rule
                  page appears.
- Configure the following options:
                    - Bridge Service: Select the Bonjour service from the
                      list.
- From VLAN: Select the VLAN from which the Bonjour
                      service will be advertised.
- To VLAN: Select the VLAN to which the service should
                      be made available.
- Notes: Add optional notes for this rule.
- Click OK.You have created a Bonjour policy
                  rule.
- Click OK.
You have created a Bonjour policy with a rule.
 You can also edit, clone and delete
        the policy by selecting the options
Configure,
Clone and
Delete respectively, from the
Gateway tab.
You may now continue to apply this Bonjour gateway policy to an AP or AP group, as
      described in
Applying a Bonjour Gateway Policy to an AP or AP Group.
