Applying a Bonjour Gateway Policy to an AP or AP Group
Once a Bonjour Gateway policy is created, you can select which AP (or AP group) will serve as the gateway for Bonjour services.
To apply a Bonjour Gateway policy to an AP or AP group:
    - Go to Access Points > Access Points.
- Select the AP or AP group that you want to configure from the zone in which the AP/group exists.
- Click Configure.
- Expand the Advanced Options, and in Bonjour Gateway, enable the check box next to Enable as Bonjour Gateway with policy, and select the policy you created from the drop-down list.
- Click OK to save your changes.
