Statistics Files the Controller Exports to an FTP Server
If you added an FTP server to the controller, the controller will export statistics files to that FTP server, either on demand or based on a schedule. This is however only applicable for SZ300 and vSZ-H.
After the feature is enabled, each controller node sends a zip file to the FTP server via FTP or SFTP, on an hourly basis. The zip file is named as: <directory_name> + '_' + <controller_node_identifier> + ".zip" .
Here, directory_name is named as yyyymmddhh (indicating the beginning of the hour that the data was received). For example, the directory name for the data that comes between 10 and 11 AM of May 26, 2016, is "2016052610" .
The zip file contains all the reported data collected within the hour.
The data is divided into tables, and each data table is associated with files. The files are named as follows: <Table Name> + '_' + <Thread_ID> + '_' + <Sequence_No>.csv.
Here, Table Name is as described in TableĀ 56. Thread_ID is an integer, and Sequence_No is from 1 to N to limit each file to be capped around 1G bytes.
| Table Name | Table Description |
| APStatus | Root for all Status: Cluster, Domain, Zone info |
| APStatusSystem | AP Level Info |
| APStatusRadio | AP Radio Info |
| APStatusWlan | AP Wlan Info |
| APStatusTunnel | AP Tunnel Info |
| APStatusIPSec | AP IPSec Info |
| APStatusIPSecStats | AP IPSec stats |
| LanPortStatus | AP Lan Port Status |
| CertificateReload | AP Certificate Reload Info |
| CableModemInfo | Cable Modem inside AP |
| APStatusLBS | Location-Based Service |
| APStatusBrownout | AP Voltage Brownout Event |
| APReportStats | Root for all ReportCluster, Domain, Zone Info |
| APReportBin | Little Bin info |
| APReportBinRadio | Radio Stats |
| APReportBinWlan | Wlan Stats |
| APReportBinClient | Client Stats |
| APReportBinTunnel | Tunnel Stats |
| APReportBinIPSec | IPSec Stats |
| APClientStats | Root for all Client |
| APClientInfo | Client Stats |
| APClientRadio | Radio Static Info |
| APClientWlan | Wlan Static Info |
| APMeshStats | Root for all Mesh |
| APMeshDownlink | Mesh Downlink AP |
| APMeshUplink | Mesh Uplink AP |
| APMeshNeighbor | AP Mesh Neighbor |
| ArcMessage | Root for all AVC |
| FlowMessage | AVC Flow |
| RogueAPStats | Root for all Rogue |
| ReportType | Rogue Devices |
