Diagnostics
- Applying Scripts
New AP models and firmware updates are supported without the need to upgrade the controller image by using AP patch files and diagnostic scripts. - Uploading AP CLI Scripts
You can upload AP CLI scripts to the controller which make the controller compatible with new AP models and new firmware without the need to upgrade the controller image. - Viewing and Downloading Logs
The controller generates logs for all the applications that are running on the server. - Viewing DHCP and NAT Information
You must be aware of the DHCP and NAT information of the controller to monitor the health of the controller. - GGSN
- RADIUS
