Viewing DHCP and NAT Information
You must be aware of the DHCP and NAT information of the controller to monitor the health of the controller.
- Go to Diagnostics > DHCP & NAT .
Select the following tabs to monitor:
- DHCP Relay (DP): To monitor the DHCP relay information of the Data Planes. Displays information the of DHCP relay packets when DHCP relay is enabled in
Core Network Tunnel >
Bridge or L2oGRE.
Figure 220 Diagnostics - DHCP Relay
- TTG (DHCP Proxy): To monitor TTG (DHCP Proxy) information of the Data Planes. Displays information on the TTG packets of DHCP relay when DHCP relay is enabled in
TTG+PDG.
Figure 221 Diagnostics - TTG (DHCP Proxy)
- DHCP (DP): To monitor the DHCP DP information of the Data Planes. Display information of the DP DHCP server packets and the number of IPs assigned .
Figure 222 Diagnostics - DHCP DP
- NAT (DP): To monitor the NAT DP information of the Data Planes. Displays information of the DP NAT server packets and the number of used ports.
Figure 223 Diagnostics - NAT DP
Bridge or L2oGRE.
Parent topic: Diagnostics
