A non proxy AAA server is used when the APs connect to the external AAA server directly.
		  Go to
		  Select the
			 Non-Proxy tab, and then select the zone for which you want to create the AAA server.
		  Click
			 Create.
		   The
			  Create AAA Server page appears.
			  Figure 156
             Creating an AAA Server
		  Configure the following:
				- General Options
					 - Name: Type a name for the AAA server that you are creating.
- Description: Type a short description of the AAA server.
- Type: Select
						RADIUS Accounting.
						Cluster Redundancy: Click the
						Enable Service for Standby Cluster option to enable cluster redundancy.
- Backup RADIUS (appears if you clicked RADIUS above): Click the Enable Secondary Server check box if a secondary RADIUS server exists on the network.
- If you selected RADIUS, configure the following options in the Primary and Secondary server sections:
					 - IP Address: Type the IP address of the AAA server.
- Port: Type the port number of the AAA server. The default RADIUS server port number is 1813.
- Shared Secret: Type the AAA shared secret.
- Confirm Secret: Retype the shared secret to confirm.
		  Click
			 OK.
You have completed creating a Non-proxy Accounting AAA server.
For information on how to test this server, see
		  Testing AAA Servers
 You can also edit, clone and delete an AAA server by selecting the options
Configure,
Clone and
Delete respectively, from the
Non-Proxy tab.
