Working with WLAN Schedule Profiles
A WLAN schedule profile specifies the hours of the day or week during which a WLAN service will be enabled or disabled.
For example, a WLAN for student use at a school can be configured to provide wireless access only during school hours. Create a WLAN schedule profile, and then when you configure a WLAN, select the schedule profile to enable or disable the WLAN service during those hours/days.
This feature will not work properly if the system does not have the correct time. To
ensure that the system always maintains the correct time, configure an NTP server and point
the system to the NTP server's IP address, as described in Configuring System Time.NOTE
WLAN service schedule times should be configured based on your browser's current
timezone. If your browser and the target AP/WLAN are in different timezones, configure the
on/off times according to the desired schedule according to your local browser. For example
if you wanted a WLAN in Los Angeles to turn on at 9 AM and your browser was set to New York
time, please configure the WLAN service schedule to enable the WLAN at noon. When
configuring the service schedule, all times are based on your browser's timezone
setting.
