Extracting a Zone Template
You can extract the current configuration of a zone and save it as a zone template.
Follow these steps to extract the configuration of a zone to a zone template:
  1. From the Access Points page, locate the zone from where you want to extract the WLAN template.
  2. Click More and select Extract Zone Template, the Extract Zone Template dialog box appears.
  3. In Zone Template Name, enter a name for the Template.
  4. Click OK, a message appears stating that the zone template was extracted successfully.
  5. Click OK. You have completed extracting a zone template.
    The extracted Zone template can be viewed under System > Templates > Zone Templates.
