Applying a Zone Template
You can apply an AP zone configuration template to a zone.
Follow these steps to apply a zone template:
  1. From the Access Points page, locate the zone where you want to apply the zone template.
  2. Click More and select Apply Zone Template, the Import Zone Template dialog box appears.
  3. From the Select a Zone template drop-down, select the template.
  4. Click OK, a confirmation message appears asking to apply the zone template to the AP zone.
  5. Click Yes. The zone template was applied successfully.
    You have completed applying zone template to the AP zone.
