An operator profile defines all the properties
pertaining to an operator while a service profile defines the properties related to a service
provider. If a WLAN is configured to provide Hotspot 2.0 service, it must be linked exactly like
a Hotspot 2.0 operator profile.
Go to .
Select the Hotspot 2.0 tab, and then
select the device for which you want to create the profile.
Click Create.
The
Creating Hotspot 2.0 WiFi Operator Profile page appears.
Figure 111
Creating a hotspot 2.0 WiFi operator profile
Configure the following:
- Name: Enter a name for this Wi-Fi operator profile.
- Description: Enter a description for the venue profile.
- Domain Names: HS2.0 operator's domain name is a mandatory field, which specifies the
operator’s domain name. Hotspot 2.0 AP broadcasts the domain name to indicate the home
Wi-Fi providers.
- Signup Security: This is an optional field and is disabled by default. Enabling
would mean that operator supports secure onboarding (OSEN).
- Certificate: Select the certificate for the operator - AAA. This can be the same
certificate as the one used with OSU service.
- Friendly Names: HS2.0 operator's friendly name is a mandatory field. Operator's
friendly name is displayed on mobile client's screen. It is also used for operator
verification during secure onboarding (OSEN). Select the display language from the
drop down list.
Click OK.
