Rate Limiting Ranges for Policies
You can define and apply rate limit values for user devices to control the data rate and types of network traffic the device transmits.
For SmartZone release 3.4 and 3.2.x, the APs support the following rate limiting
values:- 0.10Mbps
- 0.25Mbps - 20.00Mbps (increments by 0.25Mbps)
- 21.00Mbps - 200.00Mbps (increments by1.00mpbs)
For SmartZone release 3.1.x, the APs support the following rate limiting values:- 0.10Mbps
- 30.00Mbps
- 40.00Mbps
- 50.00Mbps
Policy | Global or Zone | Rate limit range for zone running SmartZone 3.4 | Rate limit range for zone running SmartZone 3.2.x | Rate limit range for zone running SmartZone 3.1.x |
Device Policy | Zone | 0.1 Mbps to 200 Mbps Support uni-direction (Uplink and Downlink need not be enabled or disabled at the same time) |
0.1 Mbps to 200 Mbps No support for uni-direction (Uplink and Downlink need not be enabled or disabled at the same time) |
0.1 Mbps to 200 Mbps. But any rate greater than 50Mbps will be mapped to 50
Mbps implicitly on the AP side when the rate is applied. No support for uni-direction |
User Traffic Profile | Global | 0.1 Mbps to 200 Mbps No support for uni-direction because this is Global profile that is used by 3.2.x and 3.1.x APs |
0.1 Mbps to 200 Mbps No support for uni-direction |
But any rate greater than 50Mbps will be mapped to 50 Mbps implicitly on the AP
