Monitoring WLAN Services
When you select a System, Domain, Zone, or AP Group from the hierarchy tree, respective contextual tabs appear at the bottom of the page.
These tabs are used to monitor the selected group. The following table lists the tabs that appear for System, Domain, Zone, and AP Group.
Table 12 System, Domain, Zone, and AP Groups Monitoring Tabs
Tabs Description System Domain Zone AP Groups
General Displays group information Yes Yes Yes Yes
Configuration Displays group configuration information. Yes Yes Yes Yes
Health Displays historical health information. Yes Yes Yes Yes
Traffic Displays historical traffic information. Yes Yes Yes Yes
Alarm Displays alarm information. Yes Yes Yes Yes
Event Displays event information. Yes Yes Yes Yes
Clients Displays client information.
Selecting the Enable client visibility regardless of 802.1X authentication check box bypasses 802.1X authentication for client visibility. This option allows you to view statistical information about wired clients even without enabling 802.1X authentication.
Yes Yes Yes Yes
WLANs Displays WLAN information. Yes Yes Yes NA
Services Displays information on the list of services. Yes Yes Yes NA
Administrators Displays administrator account information. Yes NA NA NA
Additionally, you can select System, Domain, or Zone and click More to perform the following operations as required:
  • Move
  • Create New Zone from Template
  • Extract Zone Template
  • Apply Zone Template
  • Change AP Firmware
  • Switchover Cluster
  • Trigger Preferred Node
