You can copy the configuration settings from a working switch to one or multiple new switches.
From the left pane, select
Switches.
The
ICX Switches page appears.
Select the switch group and then the
Configuration tab.
Figure 73
ICX Switch Group Configuration Tab
Click
Copy Configuration To and select the switch or group to which you want to copy the configuration profile, and click
OK.
Click
Get Configuration From and select the switch or group from which you want to get the configuration profile, and click
OK.
