In WLANs where there is an option to tunnel the traffic, you can choose the tunneling profile the WLAN can use.
Perform the following steps to enable tunneling in WLANs.
In the Wireless LANs page, from the
System tree hierarchy, select the
Zone where you want to create a WLAN.
Click
Create.
The
Create WLAN Configuration page appears.
Figure 47
Tunneling Options while Creating a WLAN Configuration
In the
Data Plane Options section, and next to
Access Network:
text check the
Tunnel WLAN traffic box to tunnel the data traffic to a central data plane. Clear the check box if you want APs to perform local breakouts.
Next to the
Core Network: option, click the radio button for Bridge.
Next to the
Tunnel Profile: option, use the drop-down menu to select one of the tunnelling profiles—either
SoftGRE or
Ruckus GRE.
You have successfully configured the tunneling option to forward traffic in a WLAN.
