Creating Common Configuration
You can create, view, and edit the configuration settings for a group of ICX switches.
  2. Select the switch and then the Configuration tab.
    Figure 67  ICX Switch Configuration Tab
  3. In Common Configuration, click Create.
    The DNS page appears.
    Figure 68  DNS Settings
  4. Type the IP address and click Add.
  5. Click OK.
    The IP address is added to the Common Configuration page under Property and any new (factory default) switch joining this group will have the DNS configuration applied. If you want to edit the configuration, select it and click Configure to edit the settings.
    You can click the Switch AAA Settings link to view and modify the global AAA settings for the switch.
