Viewing Cluster Configuration
After you have configured cluster redundancy, you can view details of the active and standby clusters.
Cluster redundancy is supported only on SZ300 and vSZ-H.
Follow these steps to view the cluster configuration:
  1. Go to System > Cluster. The Cluster page appears.
  2. Select the cluster, scroll down and click the Configuration tab. You can view the cluster details listed in the following table.
    Table 17 Cluster Details
    Field Description Active Cluster Standby Cluster
    IP Support
    Displays IP support version Yes Yes
    Cluster Redundancy
    Status Displays the cluster redundancy status. Yes Yes
    Cluster IP list Displays cluster name, management IPs, and control IPs of standby cluster. Yes No
    Schedule Configuration Sync
    • Status—Displays sync status
    • System Time Zone—Displays the system time zone set
    • Time—Displays the sync time followed everyday
    • Last Trigger Time—Displays the date and time the clusters synced last. Applies to both scheduled sync or manually sync
    • Next Trigger Time—Displays the date and time of the next scheduled sync
    • Sync Now—Triggers manual configuration sync operation
    Yes No
    State Displays the system configuration sync state. Yes No
    Progress Status Displays the progressive status of the system configuration sync. Yes No
