Enabling the LACP Support for a Zone
Perform the following procedure to enable the LACP support for a zone.
From the left panes, click
Access Points.
The
Access Points page is displayed.
Figure 48 Viewing the Access Points
Select a zone and click
The
Configure Group page is displayed.
Figure 49 Enabling LACP Support for a Zone
- Enter the zone name.
- Under Configuration, select R720 from the Select an AP Model list.
Under
General Options, enable
LACP.
NOTEBy default, LACP is disabled.NOTETo support the LACP and LAG feature on Ruckus APs, ensure that the correct PoE mode is selected to bring up LAN1,2 ports. For example, PoE-at+ for R720, PoE-at for R710. The LACP and LAG UL throughput is limited to around 1Gbps.
- Click OK.
