If you have enabled Application Recognition and Control for at least one WLAN, you can monitor the applications that run on wireless clients associated with that WLAN.
To configure application recognition and control policies, go to
Services and Profiles > Application Control. For more information, see
Configuring Application Controls.
To monitor the top applications by traffic consumption on the wireless network:
Go to
on the main menu.
Select whether to view the
Top Applications by
Application or
Port, select a time period to display, and optionally filter the data by AP MAC address and WLAN name using the drop-down menus.
Select whether to display the Top 10 or Top 25 applications in
Chart or
Table format.
If Application Recognition and Control is unable to find an application name, it displays the source and destination IP: port address of the application
Figure 211
Top Applications - Chart View
Figure 212
Top Applications by Port - Table View
Click on an application from the list on the left (either Chart or Table view) to view a list of the top clients using the selected application in the list on the right. The client list displays the client's MAC address, OS, hostname, IP address (IPv4 and IPv6), and application usage volume and percent of application traffic generated by the client. From the
Total option, you can also filter the data based on the radio frequencies (2.4 GHz and 5 GHz).
Figure 213
Click an application to view top client details
Click on a client in the list on the right, and scroll down to the client specific details table on the bottom right to view the top 10 applications used by the client.
Figure 214
Click a client to view application details
You can configure application control policies (denial, rate limiting, and QoS) using the
Services and Profiles > Application Control page. For more information, see
