Creating Routing Configurations
You can create, edit, and delete routing configurations for an ICX switch.
    The ICX Switches page is displayed.
  2. Select the switch group or switch and click the Routing tab.
    Figure 86  ICX Switch Routing Tab
  3. In IP Ports, click Create.
    The IP Ports page is displayed.
    Figure 87  IP Ports Page
    Configure the following IP port information:
    • Switch: Select the switch from the list,
    • Name: Enter a name.
    • OSPF Area: Enter the OSPF area IPv4 address.
    • Port: Select the port number from the list.
    • DHCP Relay Agent: Enter the DHCP relay agent IP address.
    • IP Address: Enter a unicast IP address.
    • IP Subnet Mask: Enter an IP subnet mask.
    • Ingress ACL: Select the ACL for the ingress network interface.
    • Egress ACL: Select the ACL for the egress network interface.
  4. Click OK.
  5. In VE Ports, click Create.
    The VE Ports page is displayed.
    Figure 88  VE Ports Page
    Configure the following VE port information:
    • Switch: Select the switch from the list.
    • VE#: Enter the VE number. Range: 1 through 4095.
    • VLAN#: Select the VLAN from the list.
  6. Click OK.
