Working with WLAN Templates
You can create, configure, and clone a WLAN template.
To view details about a WLAN template, select System > Templates > WLAN Templates and click a zone. The respective contextual tabs are displayed at the bottom of the page.
Table 22 WLAN Templates: Contextual Tabs
Tab Description
General Displays details of the respective WLAN template.
WLAN Displays details of the respective WLAN. You can create or configure a WLAN. Refer to Creating a WLAN Configuration.
Hotspots and Portals Displays details of the respective hotspots and portals. Refer to Working with Hotspots and Portals.
Access Control Displays details of the respective access control. Refer to Configuring Access Control.
Authentication and Accounting Displays details of the respective authentication and accounting servers. Refer to Authentication and Accounting respectively.
Tunnels & Ports Displays details of the respective tunnels and ports. Refer to Working with Tunnels and Ports.
Radius Displays details of the respective VSA profiles. You can create or configure a VSA profile. Refer to Creating a Vendor-Specific Attribute Profile.
