Viewing Firmware History of the Switch
You can view the detailed status and result of the firmware update to a switch. You can also view a history of firmware upgrades that were previously carried out on the switch.
You must have upgraded the firmware of the switch as described in Scheduling a Firmware Upgrade
  2. Select the switch or group. Then select the Firmware History tab.
    The Firmware History tab is displayed.
    Figure 104  Viewing Firmware History
    You can verify the status of the upgrade from the Upgrade Job Status section which displays the time, switch ID, firmware version, image name, status and failure reasons (if any) for the upgrade.
    The Firmware Upgrade History section displays the time of the pervious upgrade operations, and firmware versions to which the upgrade was done.
