Exporting the Guest Pass to CSV
Follow these steps to export the last generated guest passes to a comma-separated value (CSV) file.
  1. From the generate guest pass list, select the guest passes that you want to export to CSV.
  2. Click Export Selected.
    Your web browser downloads the CSV file to its default download location.
  3. Go to your web browser's default download location and look for a file named guestpass.csv.
  4. Using Microsoft Excel or a similar application, open the CSV file. The CSV file displays the details of the guest passes, including:
    • Guest Name
    • Key
    • Remarks
    • Generated
    • Expiration Date
    • WLAN
You have completed exporting the last generated guest passes to CSV.
Figure 123  A sample CSV of generated guest passes when opened in Excel
