Available System Logs for platforms
The controller generates logs for all the applications that are running on the server.
The following table lists the controller applications that are running.
Table 66 Controller applications and log types for vSZ-H and SZ300
Application Description
Cassandra The controller's database server that stores most of the run-time information and statistical data
CNR An application that obtains TTG configuration updates and applies the settings to related modules
Communicator Communicates with access points and retrieves statuses, statistics, and configuration updates
Configurer Performs configuration synchronization and cluster operations (for example, join, remove, upgrade, backup, and restore)
Diagnostics An interface that can be use to upload Ruckus scripts (.ksp files) for troubleshooting or applying software patches. This interface displays the diagnostic scripts and system patch scripts that are uploaded to a node.
EAut Manages the sessions on the controller TTG module
EventReader Receives event messages from access points and saves the information into the database
Greyhound The interface between the controller TTG module and the AP interface, used to send and receive proprietary messages for AP association and disassociation
LogMgr Organizes the Application Logs into a common format, segregates them, and copies them into the respective Application log file
MdProxy MdProxy on AP and controller connect to AP-MD and controller-MD respectively. MdProxy on controller receives messages and retrieves the message header. It also forwards the response to controller-MD. This message is sent to the MdProxy on AP through AP-MD. MdProxy on the AP removes the MSL header and responds to the connection on which the request was received.
Memcached The controller’s memory cache that stores client authentication information for fast authentication or roaming
MemProxy Replicates MemCached entries to other cluster nodes
Mosquitto A lightweight method used to carry out messaging between LBS and APs
MsgDist The Message distributor (MD) maintains a list of communication points for both local applications and remote MDs to perform local and remote routing
NC The Node Controller, which monitors all controller TTG processes
NginX Is a web server that is used as a reserve proxy server or a HTTP cache
Northbound As an interface between SP and AAA, it performs UE authentication and handles approval or denial of UEs to AP.
RadiusProxy Sets the RADIUS dispatch rules and synchronizes configuration to each cluster node
Scheduler Performs task scheduling and aggregates statistical data
SNMP Provides a framework for the monitoring devices on a network. The SNMP manager is the system is used to control and monitor the activities of network hosts using SNMP. As an agent that responds to queries from the SNMP Manager, SNMP Traps with relevant details are sent to the SNMP Manager when configured.
SubscriberManagement Maintains local user credentials for WISPr authentication.
SubscriberPortal Internal portal page for WISPr (hotspot)
System Collects and sends log information from all processes
Web Runs the controller management web server
