Configuring Traffic Analysis Display for WLANs
Using traffic analysis you can measure the total volume of traffic sent or received by WLANs.
You can view historical and real-time data of the WLANs. Throughput and the number of clients connected to the WLANs are displayed in a bar chart. You must configure the WLAN settings to view its traffic analysis.
To configure the WLAN settings:
  1. From the WLAN area, click settings . The WLAN settings form displays.
    Figure 20  WLAN Settings Form
  2. In the Show top box, enter the number of WLANs for which the traffic must be analyzed. Range: 5 through 20.
  3. Select the Type radio button for the type of display you want to view. The choices are Chart or Table.
  4. Select the WLAN identification option to be displayed. The choices are Name or SSID.
  5. Click OK.
