Step 3: Transfer the Cluster Backup File to an FTP Server
  1. Log on to the controller CLI as a system administrator.
  2. Enable privileged mode on the CLI.
    ruckus> enable
    Password: ********
    ruckus#
  3. Run the copy backup command to copy the cluster backup file to an FTP server as shown in the figure.
    Figure 272  Command to copy the cluster backup file
    The names of the backup files are automatically assigned by the controller based on the timestamp when the backup file was generated and the controller release version. To make it easy for you to identify the backup files, Ruckus strongly recommends moving each node's backup file to its own directory on the FTP server (for example, //ftp/node1) after the backup process is completed.
