Ports to Open for AP-Controller Communication
The table below lists the ports that must be opened in the network firewall to ensure that the vSZ-D/SZ/vSZ (controller), managed APs, and RADIUS servers can communicate with each other successfully.
Table 67 Ports to open for AP-Controller Communication
Port Number Layer 4 Protocol From (Sender) To (Listener) Configurable from Web Interface? Purpose
21 TCP AP Control plane of
  • SZ100
  • SZ300
  • SCG200
  • vSZ
No ZD/Solo APs can download SZ AP firmware and converting themselves to SZ APs.
22 TCP
  • AP
  • vSZ-D
vSZ control plane No SSH tunnel
Port 91 (AP firmware version 2.0 to 3.1.x) and 443 (AP firmware version 3.2 and later) TCP AP vSZ control plane No AP firmware upgrade
APs need Port 91 to download the Guest Logo and to update the signature package for the ARC feature.
Starting in release 3.2, the controller uses an HTTPS connection and an encrypted path for the firmware download. The port used for AP firmware downloads has also been changed from port 91 to 443 to distinguish between the two methods. To ensure that all APs can be upgraded successfully to the new firmware, open both ports 443 and 91 in the network firewall.
161 TCP SNMP Client SZ No Simple Network Management Protocol (SNMP)
9997 TCP Client Device SZ control Plane No Internal Subscriber Portal in HTTP protocol
443 TCP
  • AP
  • vSZ-D
vSZ control plane No Access to the vSZ/SZ control plane over secure HTTPS
8443
The Public API port has changed from 7443 to 8443.
TCP Any vSZ management plane No Access to the controller web interface via HTTPS
12223 UDP AP vSZ control plane No LWAPP discovery, send image upgrade request to ZD-APs via LWAPP (rfc5412).
8022 No (SSH) Any Management interface Yes
When the management ACL is enabled, you must use port 8022 (instead of the default port 22) to log on to the CLI or to use SSH.
8090 TCP Any vSZ control plane No Allows unauthorized UEs to browse to an HTTP website
8099 TCP Any vSZ control plane No Allows unauthorized UEs to browse to an HTTPS website
8100 TCP Any vSZ control plane No Allows unauthorized UEs to browse using a proxy UE
8200 TCP
  • AP
  • DP
SZ No Captive Portal OAuth service port for HTTP
8222 TCP
  • AP
  • DP
SZ No Captive Portal OAuth service port for HTTPS
8280 TCP
  • AP
  • DP
SZ No Captive Portal Web Proxy service port for HTTPS
9080 HTTP Any vSZ control plane No Northbound Portal Interface for hotspots
9191 TCP AP-MD SZ-MD No Communication between AP-MD and SZ-MD
9300-9400 TCP SZ SZ No Internal communication between nodes within the cluster (ElasticSearch database)
9443 HTTPS Any vSZ control plane No Northbound Portal Interface for hotspots.
9998 TCP Any vSZ control plane No Hotspot WISPr subscriber portal login/logout over HTTPSl
3799 UDP External AAA Server (free Radius) SZ-RAC ( vSZ control plane) No Supports Disconnect Message and CoA (Change Of Authorization) which allows dynamic changes to a user session such as disconnecting users and changing authorizations applicable to a user session.
443 HTTPS Controller License server No Cloud license server
7000 TCP/UDP SZ SZ No Cassandra (database) cluster communication and data replication
7800 TCP/UDP SZ SZ No Cluster node communication for cluster's operations
7801 TCP SZ SZ No A protocol stack using TCP on JGroups library for node to node communication on SZ
10514 TCP SZ Local Modules (apart from Logmgr) Logmgr No Logclients (internal SZ modules) to log into Logmgr
11211 TCP memproxy
11311 TCP memcached
12311 TCP SZ (Domain JNI command) SZ (ShellAgent) No ShellAgent is an executor to receive command from Domain JNI. Use the following command to avoid forking a process from Domain that will occupy high memory usage:
java -Xms16m -Xmx32m -cp shellagent.jar:./lib/*:config com.ruckuswireless.scg.shellagent.Server
18301 TCP
  • AP
  • UE
SZ No SpeedFlex tests the network performance between AP, UE,and SZ
2083 (Radsec) TCP AAA server SZ No The default destination port number for RADIUS over TLS is TCP/2083 (As per RFC-6614)
The destination interfaces are meant for three interface deployments. In a single interface deployment, all the destination ports must be forwarded to the combined management/control interface IP address.
Communication between APs is not possible across NAT servers.
