To send guest passes via sms, you must have added an external SMS gateway to the
controller.
Follow these steps to send the guest pass via email.
From the generated guest passes list, select the guest pass that you want to send
via SMS.
Click SMS.
SMS options appear on the right side of the page (see Figure 124).
In Guest Instruction SMS Template, select the SMS template that you want to
use.
Click Add New.
In the box that appears below, type the phone number to which you want to send the
guest passes via SMS.
To add another SMS recipient, click Add New again, and then
type another phone number.
When you have finished adding all the SMS recipients, click Send
SMS.
A dialog box appears and informs you that the SMS messages have been sent to
the message queue successfully
Click OK to close the dialog box.
You have completed sending guest passes via SMS.
Figure 124
Options for sending guest passes via SMS
