Working with WLAN Templates
You can create, configure, and clone a WLAN template.
To view details about a WLAN template, select and click a zone. The respective contextual tabs are displayed at the bottom of the page.
| Tab | Description |
| General | Displays details of the respective WLAN template. |
| WLAN | Displays details of the respective WLAN. You can create or configure a WLAN. Refer to Creating a WLAN Configuration. |
| Hotspots and Portals | Displays details of the respective hotspots and portals. Refer to Working with Hotspots and Portals. |
| Access Control | Displays details of the respective access control. Refer to Configuring Access Control. |
| Authentication and Accounting | Displays details of the respective authentication and accounting servers. Refer to Authentication and Accounting respectively. |
| Tunnels & Ports | Displays details of the respective tunnels and ports. Refer to Working with Tunnels and Ports. |
| Radius | Displays details of the respective VSA profiles. You can create or configure a VSA profile. Refer to Creating a Vendor-Specific Attribute Profile. |
