Lightweight Directory Access Protocol (LDAP) is an application protocol used to access and maintain directory information services.
In addition to selecting LDAP as the server type, you must also complete the following steps for LDAP-based authentication to work on the controller.
Edit the LDAP configuration file on the LDAP server to include the service user name.
For example,
On the controller web interface, select
Administration >
Admins and Roles >
Administrators, and click
Create to create an administrator account with
super as the user name.
Select
Administration >
Admins and Roles >
Groups and assign an administrator role to the super administrator account.
When you add an AAA server for administrators, select
LDAP as the authentication server type.
Test the LDAP server using the account
username@super-login.
