If you need to release licenses bound to an offline controller and allow those licenses to be used elsewhere (on a different controller), you can download a copy of the controller licenses. The option to download a copy of the controller licenses is only available if the controller is using the
Ruckus cloud license server.
Log on to the controller web interface, and then go to
Select the
Installed Licenses tab.
Click
Download.
The
Download License page appears. In
Select Controller, select the controller node for which you want to download the license files.
You can upload and download license files only if the controller is using the
Click
Download. Your web browser downloads the license files from the controller.
When the download is complete, go to the default download folder that you have configured for your web browser, and then verify that the binary copy of the license files (with .bin extension) exists.
You have completed downloading copies of the controller licenses.
