Configuring Access Points
You can configure an Access Point.
To configure an Access Point:
- From the list, select the Access Point that you want to configure and click Configure. The Edit AP page appears.
- Edit the parameters as explained in Table 12.
- Click OK.
Select the
Override check box if you want to configure new settings.
Field | Description | Your Action |
AP Configuration > General Options | ||
AP Name | Indicates the name of the AP. | Enter a name. |
Description | Gives a short description of the AP. | Enter a short description. |
Location | Indicates generic location. | Select the check box and enter the location. |
Location Additional Information | Indicates specific location. | Select the check box and enter the location. |
GPS Coordinates | Indicates the geographical location. | Select the option. For Manual option, enter the following details:
User Location Information | Indicates the demographic information. | Enter the Area Code and Cell Identifier. |
AP Admin Logon | Indicates the admin logon credentials. | Select the check box and enter the Logon ID and Password. |
AP Configuration > Radio Options | ||
Channel Range (2.4G) | Indicates that you want to override the 2.4GHz channel range that has been configured for the zone to which this AP group belong. | Select Select Channel Range (2.4G) check boxes for the channels on which you want the 2.4GHz radios of managed APs to operate. Channel options include channels 1 to 11. By default, all channels are selected. |
Channel Range (5G) | Indicates that you want to override the 5GHz channel range that has been configured for the zone to which this AP group belong. | Select Select Channel Range (5G) check boxes for the channels on which you want the 5GHz radios of managed APs to operate. |
Radio Options b/g/n (2.4 GHz) | Indicates the radio option 2.4 GHz configurations. | Select the following options:
Radio Options a/n/ac (5 GHz) | Indicates the radio option 5 GHz configurations. | Select the following options:
Configuration > AP GRE Tunnel Options | ||
Ruckus GRE Forwarding Broadcast | Forwards broadcast traffic from network to tunnel.
NOTE ARP and DHCP traffic are allowed even if this option disabled
Click Override to enable the Ruckus GRE broadcast forwarding option. Click the Enable Forwarding Broadcast option to forward the broadcast traffic. |
AP Configuration > AP SNMP Options | ||
Override zone configuration | Allows you to override the existing zone configuration | Select the check box |
Enable AP SNMP | Enables you to configure SNMP settings. | Select the check box |
SNMPv2 Agent | Allows you to add users to SNMPv2 Agent. |
SNMPv3 Agent | Allows you to add users to SNMPv3 Agent. |
AP Configuration > Model Specific Options | ||
Model Specific Control | Indicates that the model overides the AP settings. | Select the check box. |
USB Port | Disables the USB port on the selected AP model. | Select the option. USB ports are enabled by default. |
Status LEDs | Disable the status LED on the selected AP model. | Select the option. |
LLDP | Enables the Link Layer Discovery Protocol (LLDP) on the selected AP model. | Select the option and enter the following details:
PoE Operating Mode | Allows you to operate using PoE mode. | Select the option. |
Port Settings | Indicates the port settings. | Select the option and choose the required LAN option. |
AP Configuration > Advanced Options | ||
Network Settings | Determines the network settings. | Select the IPv4 Settings from the following:
Smart Monitor | Indicates AP interval check and retry threshold settings. | Select the required check boxes. |
Syslog Options | Determines if external syslog server settings is applicable. | Select the check box and update the following details for the AP to send syslog messages to syslog server. If the primary server goes down, the AP send syslog messages to the secondary server as backup:
Hotspot 2.0 version Profile | Indicates the hotspot profile that you want to assign to the group. | Select the required option or click
Create and update the following details:
AP Management VLAN | Indicates the AP management VLAN settings. | Select the check box and choose the option.
ATTENTION For standalone APs, set the AP ethernet port to trunk before changing the AP Management VLAN settings.
Auto Channel Selection | Indicates auto-channel settings. | Select the check box and choose the option. |
Client Admission Control | Indicates the load thresholds on the AP at which it will stop accepting new clients. | Select the check boxes and update the following details:
Rogue Classification Policy | Indicates the parameters used to classify rogue APs. This option is available only if you enable the Rogue AP Detectionoption. |
Select the options for rogue classification policy:
Recovery SSID | Allows you to enable or disable the Recovery(Island) SSID broadcast on the controller. | Enable Recovery SSID Broadcast |
Direct Multicast | Indicates whether multicast traffic is sent from a wired device, wireless device or from the network. | Select one or more of the following:
Swap Configuration | ||
Add Swap-In AP | Allows to swap APs. | Select the check box and enter the Swap-in AP MAC details. |
You can also move the location of an AP or delete an AP. To do so, select the AP from the list and click
Move or
Delete as required.
