Creating DP Zone Affinity Profile
The vSZ-D version in the same zone affinity profile must be the same for consistent AP/DP functioning.
This feature is supported only for vSZ-E and vSZ-H platforms.
To create DP zone affinity profile:
- Go to System > Cluster > DP Zone Affinity.
- Click Create, the Create New DP Zone Affinity form appears.
- Enter a Name and Description for the zone affinity.
- Click Add, the Add DP form appears. Profiles with only one or two Data Planes are listed in the drop-down.
- Choose a Data Plane from the drop-down and click OK.
- Click
OK.
You have created a DP zone affinity profile.
You can also edit or delete a zone affinity profile. To do so, select the profile from the list and click
Configure or
Delete as respectively.
Verifying DP and Profile Version Match
From the list, the DP(s) Version Match column indicates Yes if the DP Profile and the DP have the same version and No if they have a different version. You can click the DPs tab to check the version of the DP.
Verifying Zone and Profile Version Match
The Zone version must match the version of the Zone Affinity Profile. Click the Zones tab to view the list of zones and its versions. Click the Show version mismatched zone(s) only button to view zones with version difference.
