You can configure the Ruckus GRE tunnel profile of
the controller to manage AP traffic.
Go to .
Select the Ruckus GRE tab, and then
select the zone for which you want to create the profile.
Click Create.
The
Create Ruckus GRE Profile page appears.
Figure 137
Creating a Ruckus GRE Profile
Configure the following:
- Name: Type a name for the profile.
- Description: Type a description for the profile.
- Ruckus Tunnel Model: Select a protocol to use for tunneling WLAN traffic back to the
controller.
- GRE + UDP: Select this option to allow APs behind a NAT server to tunnel WLAN
traffic back to the controller.
- GRE: Select this option to tunnel regular WLAN traffic only.
- Tunnel Encryption: Select the Enable tunnel encryption check
box if you want managed APs to decrypt 802.11 packets, and then use an AES encrypted
tunnel to send them to the controller. By default, when WLAN traffic is tunneled to
the controller, only the management traffic is encrypted; data traffic is
unencrypted.
- WAN Interface MTU: Set the maximum transmission unit (MTU) for the tunnel to either
Auto (default) or Manual (a specific size 850 to
1500 bytes). MTU is the size of the largest protocol data unit that can be passed on
the controller network.
- Click OK.
You have created the Ruckus GRE profile.
You can also edit, clone and delete the
profile by selecting the options
Configure,
Clone and
Delete respectively, from the
Ruckus GRE tab.
