Replacing System Fans
The controller includes six redundant, hot-swappable system fans (four 80mm fans and two 60mm fans). There are also two fans located inside the power supply units. Redundancy for the two PSU fans is only achieved when both PSUs are installed.
If any of the system fans requires replacement, the replacement procedure is identical.
Electrostatic discharge (ESD) can damage internal components such as printed circuit boards and other parts. Ruckus recommends that you only perform this procedure with adequate ESD protection. At a minimum, wear an anti-static wrist strap attached to the ESD ground strap attachment on the front panel of the chassis.
Follow these steps to replace a system fan.
  1. Open the front chassis cover of the controller. It may be necessary to extend the controller into a maintenance position.
  2. Identify the faulty fan. Each fan has a "service required" LED that turns amber when the fan is malfunctioning.
  3. Remove the faulty fan by grasping both sides of the fan assembly, using the plastic finger guard on the left side and pulling the fan out of the metal fan enclosure.
  4. Slide the replacement fan into the same metal fan enclosure. Use the edges of the metal enclosure to align the fan properly and ensure the power connector is seated properly in the header on the side of the enclosure.
  5. Apply firm pressure to fully seat the fan.
  6. Verify that the (service required) LED on the top of the fan is not lit.
  7. Close the front chassis cover and return the controller to its normal position in the rack, if necessary.
    Figure 200  Replacing a system fan
