Configuring Advanced Gateway Options
You can configure advanced gateway options. This feature no longer depend on flat file changes.
To configure advanced gateway options:
- Go to System > General Settings > Gateway Advanced.
- Configure the following options:
- Allow Session on Accounting Fail—Allows the controller TTG to terminate calls if accounting response fails. The default setting is No.
- GTP Network Service Access Point Identifier [NSAPI]—Selects NSAPI for GTP message. The default setting is 1.
- Include IMEI IE in GTP Messages—Enables or disables IMEI IE in GTP messages. The default setting is
No.
NOTEIn IMEI IE, the controller will send the MAC address of the UE appended with FFFE.
- Include ECGI in GTPV2 Messages—Used only when the S5/S8 interface is used for GTPv2:
- Include TAI in GTPV2 Messages—Used only when the S5/S8 interface is used for GTPv2.
- GTPv2 Interface Type—Choose the interface type. S2a or S5_S8.
NOTEThe default GTPv2 interface for the controller is S2a.
- Click OK.
