Creating User Groups
Creating user groups and configuring their access permissions, resources and administrator accounts allows administrators to manage a large number of users.
- Go to Administration > Admins and Roles.
- Select the Groups tab.
Click
Create after selecting the system domain.
The Create User Group page appears.
Configure the following:
- Permission
- Name: Type the name of the user group you want to create.
- Description: Type a short description for the user group you plan to create.
- Permission: Select one of the access permission for the user group, from the drop-down menu. You can also grant admin permission to generate guest passes. Select the Custom option to manually assign role-based permission in the Resource tab page.
- Account Security: Select the account security profile that you created to manage the administrator accounts.
- Click Next.
Resource: From
Select Resources, choose the resources that you want to assign to this user group. If you have selected
Custom permission option in the previous step, you can assign the required permission (Read,
Modify or
Full Access) to these resources. The resources available are SZ, AP, WLAN, User/Device/App, Admin, Guest Pass, MVNO and ICX. Click the
icon and they appear under
Selected Resources now. Use the
icon to deselect the resources assigned to the group. To select the right set of resource permission, refer
Resource Group Details.
NOTETo create User Groups, migrating Domain User Roles prior to 3.5, with DPSK permissions, Users must be granted with "User/Device/App" resource. - Click Next.
Domain: Select the domain from the list of domains to which this user group will be associated. From
Select Domains, choose the domains you want to assign to this user group. Click the
icon and they appear under Selected Domains now. Use the
icon to deselect the domains assigned to the group.
- Click Next.
Administrator: From
Available Users, choose the users you want to assign to this user group. Click the
icon and they appear under Selected Users now. Use the
You can also create Administrator Accounts by clicking the
icon to deselect the users assigned to the group.
icon. The
Create Administrator Account page appears where you can configure the administrator account settings. You can edit the user settings by clicking the
icon and delete the user from the list by clicking
icon.
- Click Next.
- Review: Verify the configuration of the user group. Click Back to make modifications to the configuration settings.
- Click OK to confirm.
- Permission
You have created the user groups.
You can also edit and delete the group configuration by selecting the options
Configure, and
Delete respectively, from the
Groups tab.
Parent topic: Managing Administrator and Roles
