Creating Bonjour Gateway Policies
A Bonjour Gateway policy must be created for an AP zone before the policy can be deployed to an AP or group of APs.
To create a Bonjour Gateway policy:
  1. Go to Services & Profiles > Bonjour.
  2. Select the Gateway tab, and then select the zone for which you want to create the policy.
  3. Click Create.
    The Create Bonjour Policy page appears.
    Figure 133  Creating a Bonjour Gateway Policy
  4. Configure the following:
    1. Name: Type a name for the policy.
    2. Description: Type a description for the policy.
    3. Rules: Create the policy rule by configuring the following
      1. Click Create. The Create Bonjour Policy Rule page appears.
      2. Configure the following options:
        • Bridge Service: Select the Bonjour service from the list.
        • From VLAN: Select the VLAN from which the Bonjour service will be advertised.
        • To VLAN: Select the VLAN to which the service should be made available.
        • Notes: Add optional notes for this rule.
      3. Click OK.
        You have created a Bonjour policy rule.
    4. Click OK.
You have created a Bonjour policy with a rule.
You can also edit, clone and delete the policy by selecting the options Configure, Clone and Delete respectively, from the Gateway tab.
You may now continue to apply this Bonjour gateway policy to an AP or AP group, as described in Applying a Bonjour Gateway Policy to an AP or AP Group.
