Each VLAN pool can contain up to 16 VLANs, and a
maximum of 64 VLAN pools can be created. Each WLAN can be configured with a single VLAN
pool.
Go to .
Select the VLAN Pooling tab, and then
select the zone for which you want to create the profile.
Click Create.
The
Create VLAN Pooling page appears.
Figure 104
Creating a VLAN Pooling Profile
Configure the following:
- Name: Type a name for the VLAN profile.
- Description: Type a short description for this profile.
- VLANS: Type the VLAN IDs to be assigned to this pool. VLAN IDs can be separated by
hyphens, commas, or a combination (for example, 7-10, 13, 17, 20-28).
- Click OK.
You have created the VLAN Pooling profile.
You can also edit, clone and delete a
profile by selecting the options
Configure,
Clone and
Delete respectively, from the
VLAN Pooling tab.
