Creating Time Schedules
You can control client access to the network by providing a time schedule within which the device can access the network.
  2. Select the Time Schedule tab, and then select the zone for which you want to create the schedule.
  3. Click Create.
    The Create Time Schedule Table page appears.
    Figure 109  Creating a Time Schedule Table
  4. Configure the following:
    1. Schedule Name: Type a name for the schedule you want to create.
    2. Schedule Description: Type a short description for this schedule.
    3. Draw the schedule table.
    4. Click OK.
You have created the schedule.
You can also edit, clone and delete the schedule by selecting the options Configure, Clone and Delete respectively, from the Time Schedule tab.
