Testing AAA Server (Auth)
To ensure that the controller administrators will be able to authenticate successfully with the RADIUS server type that you selected, Ruckus strongly recommends testing the AAA server after you set it up.
The test queries the RADIUS server for a known authorized user and return groups associated with the user that can be used for configuring roles within the controller.
  1. Go to Services & Profiles > Authentication.
  2. Select the Non-Proxy (AP Authenticator) tab, and then select the zone for which you want to test the AAA server.
  3. Click Test AAA.
    The Test AAA Server page appears.
    Figure 126  Testing an AAA Server
  4. Configure the following:
    1. Name: Select one of the AAA servers that you previous created.
    2. Protocol: Select the Password Authentication Protocol (PAP), or the Challenge Handshake Authentication Protocol (CHAP) to authenticate the AAA server.
    3. User Name: Type an existing user name on the AAA server that you selected.
    4. Password: Type the password for the user name you specified.
  5. Click Test.
    If the test was unsuccessful, there are two possible results (other than success) that will be displayed to inform you if you have entered information incorrectly: Admin invalid or User name or password invalid. These results can be used to troubleshoot the reasons for failure to authenticate administrators with an AAA server through the controller.
You have completed testing the non-proxy AAA servers that you created.
