Configuring WiFi Calling in WLAN
You can also edit the WLAN configuration to select a WiFi calling profile.
  1. Go to Wireless LANs.
  2. Select the WLAN for which you want to enable WiFi calling and click Configure.
    The Edit WLAN Configuration page appears. You can also enable WiFi calling when you create a fresh WLAN configuration, by clicking Create.
    Figure 122  Configuring WiFi Calling in a WLAN
  3. In Advanced Options, move the WiFi Calling radio button to ON. WiFi calling is enabled.
  4. Click Select.
    The WiFi Calling Policies page appears.
    From the list under Available Profiles, identify the ones you want and click the -> icon. The profile(s) is moved under Selected Profiles. You can use the <- icon to de-select the profile for the WLAN.
  5. Click OK.
    The profile(s) selected are displayed under the WiFi Calling Profile field.
You have selected the WiFi calling profile that you want to apply to the WLAN.
