Web authentication (also known as a “captive
portal”) redirects users to a logon web page the first time they connect to this WLAN, and
requires them to log on before granting access to use the WLAN.
Go to .
Select the Web Auth tab, and then select
the zone for which you want to create the portal.
Click Create.
The
Create Web Authentication Portal page appears.
Figure 94
Creating a Web Authentication Portal
Configure the following:
- General Options
- Portal Name: Type a name for the hotspot service portal that you are
creating.
- Portal Description: Type a short description of the hotspot service portal.
- Language: Select the display language that you want to use on the web
authentication portal.
- Redirection: select where to redirect the user after successfully completing
authentication.
- Start Page: select one of the following
- Redirect to the URL that the user intends to visit: Allows the guest user to
continue to their destination without redirection.
- Redirect to the following URL: Redirect the user to a specified web page
(entered into the text box) prior to forwarding them to their destination.
When guest users land on this page, they are shown the expiration time for
their guest pass.
- User Session
- Session Timeout: Set a time limit (in minutes) after which users will be
disconnected from the hotspot service and will be required to log on again.
- Grace Period: Set the time period (in minutes) during which disconnected users
are allowed access to the hotspot service without having to log on again.
Click OK.
You have completed creating a Web Auth service portal.
You can also edit, clone and
delete a Web Auth service portal by selecting the options
Configure,
Clone and
Delete respectively, from the
Web Auth tab.
