Applying a WLAN Template
You can apply the WLAN template to zones where the AP's firmware version is later than the Zone templates firmware version. Unsupported firmware version of the WLAN template is automatically upgraded to its next version before being upgraded to the current version.
To Apply a WLAN template to a zone:
- From the application select, System > Templates > WLAN Templates.
- From the list, select the WLAN template that you want to apply and click Apply. The Apply WLAN Template to selected zones form appears.
From
Available AP Zones, select the required zone and click the
Move button.
- Click Next, the Apply WLAN template to selected zones form appears.
- Select the required options:
- Create all WLANs and WLAN profiles from the template if they don't already exist in the target zone(s)
- If the target zone(s) has WLANs or WLAN profile with the same name as the template, overwrite current settings with settings from the template.
- Click OK, you have applied the template to the zone.
